Hey,thanks for the replies.If you are in cPanel, there is a problem with XCache. You can't view the XCache GUI control panel.
You can run Litespeed + PHP Cache which is a great combination and works very well with cPanel. Litespeed, however, is not a free application.Hey,thanks for the replies.
I am indeed using cPanel,but with EAccelerator and running a vbulletin site on my VPS,is that fine or?Any other 3rd party apps to recommend to install and optimise that please?![]()
