WHMCS Question
Justme
Preinstallation system checks all passed except for "Register Globals". Register Globals are to be on for this WHMCS to function correctly. It says it can be enabled in a .htaccess or php.ini file in my WHMCS directory.
I went to WHMCS and followed instructions to create a .htaccess file and upload it to my WHMCS folder. No go.
#1 how do i turn on Register Globals for this software? Register Globals only need to be turned on for the main website which runs WHMCS.
#2 Off to try creating a php.ini file and inserting this into the main WHMCS folder AND the Admin folder as per WHMCS.
Is there an easier option?
Thanks,!
Hi, you need to add a few lines to your htaccess file...
<IfModule mod_php4.c>
  php_value register_globals 1
</IfModule>
<IfModule sapi_apache2.c>
</IfModule>
Thanks for the help.
I tried this and I continue to receive and Error message.
I was also given the code: php_value register_globals 1 and also received errors. I have a ticket going, hopefully that takes of the issue.
btw, knownhost has been more then great with support! WTG KH!
