VPS with Fantastico
U
Unregistered
I am looking at taking up a new VPS and was wondering if I should also take on Fantastico (only $1 per month I know). I have used Joomla on a number of sites (native installs) and have in the past experienced major issues in the setting of file and directory premissions.
I have never installed Joomla with Fantastico before, so can can you please tell me if this improves the installation experience by setting all the correct permissions or if I still need to do that myself.
Thanks for your Help
Fantastico takes care of permission settings and will allow you to setup Joomla with a click or two. Most clients use it so worse case you can remove it if you don't like it. Hope this helps.
U
Unregistered
Thanks Joel for you very quick response. One last question - will Fantastico install the latest version 1.5x or will it be 1.0x?
