Virtuozzo Firewall Settings
kubel
Anyone have any experience tweaking the firewall settings in virtuozzo's control panel that can share some tips?
Icy
:(. Unfortunately I enabled firewall from my Power Panel & after that I can't login to WHM & cPanel. VZPP is also tramendous slow :(.
sontran
You can click Add rule and then Set the name as WHM with the destination port is 2086 (other setting is tcp, input... just leave them as is) Do the same for Cpanel at port 2082 and Webmail: 2095
Son tran
