G GPro New Member Feb 12, 2009 #1 Is the process to upgrade php to 5.2.8 the same as the tutorial dated '07? Thanks GPro
Dan Moderator Feb 12, 2009 #2 It is yes. There are a lot of options that aren't touched on in it but so long as you read the notes on them (some are not compatible with others) and don't select everything, just what you need or the even just the defaults, you should be ok.
