The SSL certificate for exim on host.---.com will expire in less than 30 days
Gimpy
I stated getting this notification over the weekend...
Your server's SSL certificate for exim will expire in less than 30 days. You need to
install a new certificate as soon as possible. You can install a new certificate
using WHM's "Manage Service SSL Certificates" interface:
I was not aware I had a SSL Certificate. Can someone explain what I need to do here?
Hi Gimpy,
It's a self-signed certificate and you can generate a new one. Log into your WHM and go to Service Configuration | Manage Service SSL Certificates and then in the chart on the right hand side under Actions you should have the option to create a new one.
Ah @Dan beat me here by a minute. He's correct that it's just the self-signed and simple to reset - or will automatically do so on it's own in ~30 days when the expiration date is reached.
