SpamAssassin missing
Aarem
In all of my CPanel accounts, SpamAssassin does not appear in the list of options, although BoxTrapper and the other email related options do. The Package for each account is the default (SpamAssassin etc ticked), so where is it?
I'm using CPanel x3.
Help!
Hi Aarem,
Please check the WHM >> Service Configuration >> Service Manager screen to make sure "spamd" service is enabled there
Aarem
Aha! Thank you Paul. It was actually on, but the note next to this section says to check Tweak Settings, and it was turned off there. Problem solved. Thanks for such a quick response.
