smf spell checker
You'll need to go through the entire Apache Update process and make sure you click to see the Advanced options in step 6. There's a checkbox for the Pspell module near the bottom.
mylinear
Root WHM -> Software -> Apache Update. You can browse through the options in each step there as long as you don't click any "Build" button / option which will start the recompilation process.
RSprinkel
I am needing the same thing. Now a quick question. khiltd - when you say "You'll need to go through the entire Apache Update process", should we temporarily disable the server or does this happen behind the scenes of everything?
Sorry for the newbie question, but everything is going Great so far and I don't want to take any chances of messing up a good thing.
Thanks much in advance.
RSprinkel
