I got this email and dont know what to do can someone help?
IMPORTANT: Do not ignore this email.
The hostname (host.tciforums.org) resolves to . It should resolve to 72.249.86.158. Please be sure to correct /etc/hosts as well as the 'A' entry in zone file for the domain.
Some are all of these problems can be caused by
/etc/resolv.conf being setup incorrectly. Please check this file if you
believe everything else is correct.
You may be able to
automaticly correct this problem by using the ' Add an A entry for your
hostname ' under ' Dns Functions ' in your Web Host Manager
You may be able to
