Installed Perl Modules?
fabb
Hi all,
I installed some modules via shell. Shell confirmed that they installed properly; Support (ticket 23065) sees the modules installed, however WHM/cPanel's System Installed Modules page do not show them. Does anyone know why they're not listed?
P.S. Hi Jay! Thanks for dragging me into your realm. :D
computervitals
Could be a permissions issue.
I had an account on my vps that would show any permissions.
If you go to /home/user/.cpaddons
Double check the *.yaml and the moderation folder.
I found some had the permissions set to root.
I changed the owner of the folder and yaml files to the username and reopened the cpanel and they showed up.
But if you are talking they dont show in WHM's listing then I dont know if that will help.
