httpd/cpanel unstable.
keyo
I get emails every day like:
httpd failed @ [time] on host.mydomain.com...
Unable to conect to port 80
and
tailwatchd failed @ [time]
cpsrvd failed @ [date][time] A restart was attempted automagically.
Service Check Method:  [tcp connect]
Failure Reason: Unable to connect to port 2086
Also when I restart apache this comes up...
[error] VirtualHost [my ip address]:0 -- mixing * ports and non-* ports with a NameVirtualHost address is not supported, proceeding with undefined results
Website has been down more frequently than I expect. Quite frequently my whm login will not work or only show two blank frames. Please help, the reason I moved to a new host is for reliability.
bogey9000
SHADO Operative
If you haven't already done so open up a support ticket. They're pretty good. I've had my VPS more than a year and never had problems like this. Any issues that did come up support has been quick and competent at fixing them.
good luck!
Mike
keyo
I found out what the real problem is now. PHP seems to be running out of memory.
Found this in my error logs...
[Tue May 19 08:45:34 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/local/apache/bin/suexec)
[Tue May 19 08:45:34 2009] [warn] pid file /usr/local/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue May 19 08:45:34 2009] [notice] Apache/2.2.11 (Unix) mod_ssl/2.2.11 OpenSSL/0.9.8e-fips-rhel5 mod_bwlimited/1.4 PHP/5.2.9 configured -- resumin$
Hello keyo,
The log snippet you posted just means that Apache did not have a clean shutdown and the pid file was still there. Although I would suspect that you are right and you are running out of ram which would cause services to crash/shutdown.
