How to migrate to CentOS 5.x
bartprokop
Can you give me the quick path to migrate to Cent OS 5.x?
Is the simplest method just to backup it all, then reinstall VPS and then set it up again using conf files and content from backup?
Bart
Hello Bartprokop,
In a VPS you don't have access to the main OS on the machine and you cannot upgrade it.
Far as I know new VPSs being sold are provisioned with CentOS 5 so if you need it that is probably the way to go.
Hope that helps
taznumber1
I was told that only way to upgrade is to purchase a new account and then move all your stuff then close your first account
The VPS's kernel cannot be upgraded(or touched) by a user. However, the OS of the specific VE(Virtual Environment) can be upgraded.
Create a ticket to receive the specific steps involved. I'm pretty sure it does require one to purchase a new VPS and migrate.
