How to block Baidu spider and other BadBots.
Dave G
I can't seem to find the post about the person who wanted to stop Baidu spider here is how I do it.
I your WHM find your ConfigServer Security & Firewall then click on the "Firewall Deni IP's" button
Add the following lines just below these 2 lines:
# See readme.txt for more information regarding advanced port filtering
180.76.5.0/24 # Manually denied - Thu Dec 22 20:22:51 2011 do not delete (Baiduspider/2.0)
180.76.6.0/24 # Manually denied - Thu Dec 22 20:22:51 2011 do not delete (Baiduspider/2.0)
123.125.71.0/24 # Manually denied - Thu Dec 22 20:22:51 2011 do not delete (Baiduspider/2.0)
220.181.108.0/24 # Manually denied - Thu Dec 22 20:22:51 2011 do not delete (Baiduspider/2.0)
119.63.192.0/21 # Manually denied - Fri May 31 06:49:25 2013 do not delete (Baiduspider/2.0)
It should look like the above, click the "Change" button then click the "Restart cfs+lfd" button and wait for the restart.
If you want to block even more BadBots here is my full list including the above.
50.31.96.6 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.7 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.8 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.9 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.10 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.11 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
50.31.96.12 # Manually denied - April 18 6:22:51 2012 do not delete (IP-Web-Crawler)
176.9.139.112 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.139.113 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.146.19 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.148.194 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.148.196 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.148.197 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.155.226 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.50.103 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.134 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.135 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.136 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.137 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.138 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.140 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.141 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.143 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.155 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.156 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.194 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.196 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.198 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.204 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.206 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.211 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
176.9.51.215 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.112.179 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.112.180 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.112.66 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.112.67 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.112.68 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.115.13 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.115.48 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.115.49 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.125.26 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.127.154 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.223.170 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.27.74 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.36.119 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.81.44 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.81.45 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.81.46 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
5.9.81.47 # Manually denied - Wed Dec 25 6:22:51 2012 do not delete (crawler.sistrix.net)
108.59.0.0/20 # Manually denied - Thu Oct 2 20:22:51 2012 do not delete (TwengaBot-2.0)
208.115.111.64/28 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (dotnetdotcom.org ezooms.bot)
208.115.113.80/28 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (dotnetdotcom.org ezooms.bot)
213.186.112.0/20 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (ahrefs.com AhrefsBot/3.0)
212.113.32.0/21 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (ahrefs.com AhrefsBot/3.0)
213.186.119.0/24 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (ahrefs.com AhrefsBot/3.0)
213.186.96.0/19 # (AhrefsBot/4.0) do not delete
173.199.64.0/18 # (AhrefsBot/4.0) do not delete
127.0.0.0/8 # (AhrefsBot/4.0) do not delete
208.167.230.51 # (AhrefsBot/4.0) - do not delete - Fri May 31 06:32:28 2013
199.21.96.0/22 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (YandexBot/3.0)
95.108.128.0/17 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (YandexBot/3.0)
100.43.64.0/19 # Manually denied - Thu Feb 2 20:22:51 2012 do not delete (YandexBot/3.0)
199.36.240.0/22 # Manually denied - Sept 24 20:22:51 2012 do not delete (img-spider-yandex.com)
37.140.128.0/18 # Manually denied - Sept 24 20:22:51 2012 do not delete (img-spider-yandex.com)
54.241.195.91 # Manually denied - Sun Feb 10 05:38:33 2013 do not delete (MarkMonitor Domain Management)
54.241.66.128 # Manually denied - Sun Feb 10 05:38:33 2013 do not delete (MarkMonitor Domain Management)
54.241.65.163 # Manually denied - Sun Feb 10 05:38:33 2013 do not delete (MarkMonitor Domain Management)
188.138.48.235 # Manually denied - do not delete WBSearchBot Sat Mar 9 12:06:19 2013
62.219.0.0/16 # Manually denied - (ISRAEL Bad Bot) do not delete - Wed Oct 24 09:13:16 2012
192.114.64.0/20 # Manually denied - (ISRAEL Bad Bot) do not delete - Wed Oct 24 09:13:16 2012
82.80.0.0/15 # Manually denied - (ISRAEL Bad Bot) do not delete Sat Apr 13 05:55:27 2013
123.150.0.0/15 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
124.114.0.0/15 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
114.80.0.0/12 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
14.112.0.0/12 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
175.42.0.0/15 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
178.33.62.39 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
194.242.226.233 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
194.242.226.54 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
213.203.223.45 # Manually denied - do not delete Sat May 25 13:40:43 2013 (Sosospider/2.0)
173.192.4.194 # Manually denied - do not delete - (heritrix/1.14.3 +http://www.accelobot.com)- Thu May 30 05:55:50 2013
# Bad Bots listed above.
