Fix for runaway SpamAssassin process on cPanel systems
The following notification was received from cPanel:
Dear cPanel Partner,
There have been numerous reports recently regarding excessive CPU
utilization by spamd. This is occurring as a result of a bug in the
berkelydb implementation used by SpamAssassin, which causes spamd children
to enter an infinite loop when attempting to open a temporary file in the
user's ~./.spamassassin directory.
You can determine whether or not this is the case by executing a trace
against the spamd process in question, and monitoring the trace for
repeated calls to open() a file in ~/.spamassassin/__db.[DB_NAME].
For example, you can launch a trace on the affected process with the
following command:
strace -vvFf -s 4096 -e trace=file -p [PID]
A trace on an affected server would repeated output something similar to
the following:
open("/home/user/.spamassassin/__db.bayes_toks.new",
O_RDWR|O_CREAT|O_EXCL|O_LARGEFILE, 0600) = -1 EEXIST (File exists)
We have devised a work around for SpamAssassin, which can be applied by
taking the following steps:
killall -TERM spamd # ensure all hung spamd processes are terminated
killall -9 spamd # ensure all hung spamd processes are terminated
Visit the following WHM URL:
https://__your_sever_ip_here__:2087/scripts2/autofixer
Enter spamd_dbm_fix into the input field, and click 'Submit'
Once the patch has been applied, the spamd loads should subside. If the
problem persists after applying the patch, please let our support team
know, and they will investigate any outstanding issues.
We have notified the SpamAssassin developers of this issue, and expect
that this will be resolved in versions 3.2.4 and greater.
