eAccelerator
awehost
I was wondering if these VPS's have eAccelerator and if not is it advisable to install it.
I am finding php and most script based pages are a bit slow and I'd like to improve performance. I've thought about litespeed but it's an additional cost.
I also wonder if it's a memory hog when I have a number of accounts on the server.
Any thoughts?
KH-DanielP
KH-CEO
Personally I'd shy away from eAccelerator. If you need a php accelerator I'd recommend APC as it tends to work very well with no code changes.
awehost
Firstly, are VPS's configured with a PHP accelerator when purchased and how d I tell if one is installed?
Also, can KH install APC and is there any risk of websites breaking?
Are there any good references out there I can be pointed to?
KH-Mathew
Systems Administration
Hey awehost,
VPS's are not provisioned with any php cache by default but support will install it for you. The method I always use is to install it as a PECL extension. You can see what modules are installed currently by issuing the command "php -m" from a terminal. Here are some links for reference on APC usage:
http://php.net/manual/en/book.apc.php
http://devzone.zend.com/1812/using-apc-with-php/
http://www.if-not-true-then-false.com/2012/php-apc-configuration-and-usage-tips-and-tricks/
http://www.script-tutorials.com/how-to-use-apc-caching-with-php/
There are also some plugins for different CMS's that make use of APC. Make sure that if you use any they are from reputable sources since anyone can make a CMS plugin and distribute it.
