RaceJunkie
Would I benefit anything moving from c/panel to Direct Admin? I am using the VPS-L using c/panel and was wondering if there is that much difference in resourses?
Would you mind sharing why you would not go back to PLESK?As it stands, I would not go back to PLESK or Cpanel, especially on a vps account with limited RAM.
I can't speak much on the resources used, but I can speak on the simplicity. For someone who has never seen a control panel before, I think that DA is much easer to pick up. I use the enhanced skin and it is very intuitive for users. Yes, I have to deal with 2 or 3 levels, but they only have to deal with the one. I set up most of my users sites, and will even use the cliomail skin for users that just need to tweak email accounts and such.Thanks Caleb
I would still like to hear from someone that has used both.. And the difference in resources used by each.
Transferring user accounts between DA servers is pretty easy. You can do the complete thing from a user backup. I just transfered over a bunch of accounts to my new VPS here without a hitch.Can you transfer accounts between DA servers through a tool or even from cPanel to DA?
-Caleb
