Cpanel Stats - help
knownhoster
My cpanel for about 1 month does not show or update the bandwith stats thing. also with the space stats. my web stats awstats bit on cpanel which i found very useful dont work either, whats gone wrong ? it has stopped updating for ages now. any ideas or how to fix it ? am on VPS and have WHM access
Statistics is being processed by the cpanellogd service on cPanel servers. Check to make sure that "cpanellogd" process is running inside the VPS, if not you can start it using the following command:
/usr/local/cpanel/cpanellogd
