couple of questions
Status
Not open for further replies.
U
Unregistered
On the order system, what is the difference between -
1. Transfer My Existing Domain
2. I will use My Existing Domain and update My Nameservers only.
I have a domain name registered and am currently with an other hosting company.
Also will a VPSMca with DirectAdmin have enough memory to run spamassassin?
Transfer My Existing Domain means you will be changing your current domain registrar to us (Enom). The cost to transfer a domain is $8.95/year and you will need to obtain an EPP Auth Key from your current registrar.
I will use My Existing Domain and update My Nameservers only means you will keep your domain registration where it is now and simply update your nameservers to the information we provide you in your welcome email.
--This really depends on what else you have running on your VPS. Most likely you will need more RAM so we would recommend our VPS L plan or adding a RAM upgrade to the VPS M plan.
Please let us know if you have any further questions.
O
original poster
Bought VPS-Lca
Thanks for the help. I signed up to a VPS-L plan.
Status
