Seems like I need to setup one of these... just not sure what I should set the variables to:
ClientAliveInterval
Sets a timeout interval in seconds after which if no data has been received from the client, sshd will send a mes-
sage through the encrypted channel to request a response from the client. The default is 0, indicating that these
messages will not be sent to the client. This option applies to protocol version 2 only.
ClientAliveCountMax
Sets the number of client alive messages (see above) which may be sent without sshd receiving any messages back from
the client. If this threshold is reached while client alive messages are being sent, sshd will disconnect the
client, terminating the session. It is important to note that the use of client alive messages is very different
from TCPKeepAlive (below). The client alive messages are sent through the encrypted channel and therefore will not
be spoofable. The TCP keepalive option enabled by TCPKeepAlive is spoofable. The client alive mechanism is valu-
able when the client or server depend on knowing when a connection has become inactive.
The default value is 3. If ClientAliveInterval (above) is set to 15, and ClientAliveCountMax is left at the
default, unresponsive ssh clients will be disconnected after approximately 45 seconds.
TCPKeepAlive
Specifies whether the system should send TCP keepalive messages to the other side. If they are sent, death of the
connection or crash of one of the machines will be properly noticed. However, this means that connections will die
if the route is down temporarily, and some people find it annoying. On the other hand, if TCP keepalives are not
sent, sessions may hang indefinitely on the server, leaving "ghost" users and consuming server resources.
The default is "yes" (to send TCP keepalive messages), and the server will notice if the network goes down or the
client host crashes. This avoids infinitely hanging sessions.
To disable TCP keepalive messages, the value should be set to "no".
