CDN question
hawks
If to use custom SSL for cdn in a sub-domain,
Need to create a cdn subdomain and to install SSL on the sub-domain?
Are you able to add CNAME on the cdn sub-domain?
KH-DanielL
Creating a subdomain in cPanel is usually only needed if the record will point to your own server. Since you mention a CDN this is probably not the case, as many of those rely on a CNAME pointing to another server or host - so it seems to me like the SSL certificate would need to be installed at the CDN provider. Is there a particular CDN vendor you are trying to use? They can probably provide some advice for this question.
Trust in KnownHost, industry leading US VPS hosting suppliers.
