Can't connect to mysql using ssh tunnel
turbo2ltr
This is going to be something stupid, but I've wasted way too much time on this.
On my VPS, it seems I can no longer connect to mysql using the account's username. I know I used to be able to do this, and I can still do this on my dedicated. But for the life of me I can't get it to work anymore.
I am using navicat light and using an ssh tunnel to connect so there is no need to enable remote mysql access in cpanel. I'm even tried a root tunnel (vs a user account ) but it won't connect. The tunnel connects (based off the ssh login emails I get), but not mysql to localhost. I've tried from two different computers, with two different IPs to several different cpoanel accounts. I can no longer connect to any of them. I've tried using passwords for ssh, I've tried using keys for ssh. I have php scripts that connect fine with the mysql /account passwords I'm using.
I can use putty to ssh from either computer no issues. I can connect to mysql from a root ssh using the cpanel account credentials via command line.
In the same instance of navicat, I can connect to my dedicated server using ssh tunnels with no issues from both comptuers/IPs.
Is there anything in cpanel on my VPS that could be blocking mysql somehow?
Just a shot, if you're working on a newer server, it's probably MariaDB and not MySQL. Try Navicat for MariaDB instead. Maybe that's the issue? If not, are you getting any detailed errors?
KH-DanielP
KH-CEO
I wouldn't foresee anything VPS side that could be blocking it. I'd double check /var/lib/mysql/hostname.err to see if anything is being logged there on connection attempts. As long as you can connect via SSH with mysql -u username -p then it should work the same.
We can always dig a bit deeper in the logs but it'll be a bit more difficult for us to replicate this since we don't really use Navicat here but if you need extra help let us know.
turbo2ltr
I'm just getting a "Lost connection to MySql server at 'reading initial communication packet',. system error:0"
But if you try to connect again to the same DB, I get "cant connect to MySql server on 'localhost' (10061)." Eventually the first error comes back.
I'm sure these connections used to work. I feel like the only major thing to happen to that VPS was the recent security updates.
There was nothing of note in the err file.
So I had restarted mysql before, but now I rebooted the server and it appears it's working again! Weird.
Guess I should have tried turning it off an on again first. Duh.
onliveserver
Hii,
It's need that you have to start mysql service, it may be down, and allow mysql port 3306 in firewall/iptables.
it will connect on your local system via those credentail which you have.
In alternative you have to reset the password of root user. and it was last one step.
berkninan
Usually it indicates network connectivity trouble and you should check the condition of your network if this error occurs frequently. It might be because the MySQL server is bound to the loop-back IP (127.0.0.1 / localhost) which effectively cuts you off from connecting from "outside". If this is the case, you need to upload the script to the webserver (which is probably also running the MySQL server) and keep your server host as 'localhost' Another common cause of connect timeouts is the reverse-DNS lookup that is necessary when authenticating clients. It is recommended to run MySQL with the config variable in my.cnf:
  • Open mysql configuration file named my.cnf and try to find "bind-address", here replace the setting (127.0.0.1 OR localhost) with your live server ip (the ip you are using in mysql_connect function).
  • Restart service by command : service httpd restart
  • GRANT ALL PRIVILEGES ON yourDB.* TO 'username'@'YOUR_APPLICATION_IP' IDENTIFIED BY 'YPUR_PASSWORD' WITH GRANT OPTION;
