backup...
this is very interesting: backup with cpanel. can someone please explain in more details how it is done or point to a document on knownhost documentation section?
I am moving sites using WHM's transfer function: "Copy an account from another server with account password" and I often have troubles even with small sites.
One commom problem I have is that sometimes databases do not copy and the default package that the account is assigned is "moved". this account has no databases allowed. I was wondering weather someone has any idea how can I fix this problem.
look around your cpanel (source cpanel) for the backup link...i use rv skins so it easier for me to find it
but if you find it. after you click on it, look for this
Generate/Download a Full Backup
http://www.mountde.com:2082/frontend/rvgreen/backup/fullbackup.html
then when that is generate download it...to your comp then you can use it to restore your account in your new server
or you can try use the configure backup daily backup method
to restore to your new server
in your root whm look for..
Restore a Full Backup/cpmove file
(havn;t tried use this with the daily backup file)
(but works ok with the first method)
