Anyone using custombuild?
Jinson
Have been using custombuild for sometime on my CentOS 5 VPS. Running the latest apache, php, mysql builds. Works great. :)
BAlGaInTl
I'm still considering it for some of the features, but not sure if it is worth it, or if it will fubar my current system.
I don't think compatibility should be an issue...
I did use it to install roundcube, and that worked out quite well. However, I notice that it only has access to the inbox and not the rest of the user created folders. If you install roundcube manually on a domain, you have access to them.
I'm also a bit confused as to what dovecot will do for me or how it will affect email already on the system.
I guess I have some more reading to do before I jump in head first...
Is there a way to "undo" your custombuild changes if you don't like something?
For instance, could I now "uninstall" roundcube some how?
BAlGaInTl
I did build roundcube just to test it and it seems to have worked except...
I don't have access to any of the folders for users except for the INBOX with roundcube....
Anyone know what could cause that?
