Anybody Running OSCommerce?
mapenn
Has anybody successfully installed OSCommerce on a KH VPS? I can't get past some nagging "include path" issues, even after making adjustments to the php.ini file.
mapenn
yeah, I broke down and added fantastico to my account hoping that it would install OSCommerce more succesfully than me :). Same "include" errors as before.
Aea
Is it a general can't include error, or a open_basedir type of error that you're encountering?
It should be fairly simple to fix in cPanel, if think you would just edit php.ini to turn this setting off. In Plesk you would exit the vhost (belongs somewhere in the user directory) to set it off. Obviously you want to only do this on a per-account basis.
mapenn
Sorry about not posting a reply. The kind folks at KH helped me track down the problem. My settings were all correct....but they ended up having to [FONT=Verdana, Arial, Helvetica] recompiled Apache and PHP. After that, everything works swell.
[/FONT]
