Anouther domian problem
Your nameservers are still pointed to enom's defaults:
Name Server:DNS1.NAME-SERVICES.COM
Name Server:DNS2.NAME-SERVICES.COM
Name Server:DNS3.NAME-SERVICES.COM
Name Server:DNS4.NAME-SERVICES.COM
Name Server:DNS5.NAME-SERVICES.COM
trnt94
I changed them to ns1.tcifoums.org and ns2.tciforums.org or should the be pointed at the defaults? but now it doesnt work at all.
rezag
If its that it should be fast, years ago it used to take up to 72 or 96 hours, these days it could be as low as a few minutes for some and the same long time for others.
trnt94
Ok I changed them and it works for me, but how come when I go their the cpanel thing is still their even though it is not the index?
cPanel's default Apache config doesn't point the primary hostname to any specific account and it's more than likely reading from /usr/local/apache/htdocs. You'll have to change the DocumentRoot directive that's outside of any virtual host declarations if you want something else to happen.
trnt94
It is fine when I dont type the www, so how do I fix this, I know how to use cpanel but am unfamiliar with whm so can I have a step by step on how to do this?
rezag
I am not familiar with cpanel set up much so I can't be sure, but www. working/not working can also be a propagation issue, in fact it has happened to me over the years. If your site is working without www but with www it is going to registrar default then more than likely it needs more time to fully propagate.
