Celestial Lord
XCache is a utility that should substantially decrease server load if you serve dynamic web sites.  Note that you must be using DirectAdmin in PHP-CLI mode to get any benefit.
You can obviously use any text editor for the following. I personally use JOE:
Place the following in php.ini, before Zend:
If you'd like, type php -v, and you should see that XCache is now installed and operational.
	shell> wget http://xcache.lighttpd.net/pub/Releases/1.2.2/xcache-1.2.2.tar.gz
shell> tar -xvf xcache-1.2.2.tar.gz
	shell> cd xcache-1.2.2
shell> phpizeConfiguring for:
PHP Api Version: 20041225
Zend Module Api No: 20060613
Zend Extension Api No: 220060519
	shell> ./configure --enable-xcache
shell> make
shell> make installInstalling shared extensions: /usr/local/lib/php/extensions/no-debug-non-zts-20060613/
	shell> joe -w /usr/local/lib/php.iniPlace the following in php.ini, before Zend:
	[xcache-common]
;; install as zend extension (recommended), normally "$extension_dir/xcache.so"
zend_extension = /usr/local/lib/php/extensions/no-debug-non-zts-20060613/xcache.so
zend_extension_ts = /usr/local/lib/php/extensions/no-debug-non-zts-20060613/xcache.so
;; For windows users, replace xcache.so with php_xcache.dll
;zend_extension_ts = c:/php/extensions/php_xcache.dll
;; or install as extension, make sure your extension_dir setting is correct
; extension = xcache.so
;; or win32:
; extension = php_xcache.dll
[xcache.admin]
xcache.admin.auth = On
xcache.admin.user = "mOo"
; xcache.admin.pass = md5($your_password)
xcache.admin.pass = ""
[xcache]
xcache.shm_scheme =        "mmap"
xcache.size  =               32M
xcache.count =                 1
xcache.slots =                8K
xcache.ttl   =              3600
xcache.gc_interval =         300
; Same as aboves but for variable cache
; If you don't know for sure that you need this, you probably don't
xcache.var_size  =            0M
xcache.var_count =             1
xcache.var_slots =            8K
xcache.var_ttl   =             0
xcache.var_maxttl   =          0
xcache.var_gc_interval =     300
; N/A for /dev/zero
xcache.readonly_protection = Off
xcache.mmap_path =    "/dev/zero"
xcache.cacher =               On
xcache.stat   =               On
	shell> /etc/init.d/httpd restartIf you'd like, type php -v, and you should see that XCache is now installed and operational.
PHP 5.2.8 (cli) (built: Feb 16 2009 03:01:18)
Copyright (c) 1997-2008 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2008 Zend Technologies
with XCache v1.2.2, Copyright (c) 2005-2007, by mOo
with Zend Extension Manager v1.2.2, Copyright (c) 2003-2007, by Zend Technologies
with Zend Optimizer v3.3.3, Copyright (c) 1998-2007, by Zend Technologies
