I have found these informations on the web and this may interest you if you would like to have this last version packages wich are the most important for a website (of course I have tested and using this and all products are working perfectly):
CentOS does not provide proftpd in its reprository, you have to manually install it or an easier way is to add the repo location where proftpd is updated, follow my instructions:
go in /etc/yum.repos.d and open the file CentOS-Base.repo and add this to the bottom of the file:
The first repo utterrambling is from jasonlitka.com/yum-repository, the guy maintaining this is cool to setup this and provide us with last apache 2.2.6 php 5.2.5 for example
The second one is a redhat one compatible with CentOS wich as much more updated stuffs. (this one has proftpd 1.3.1)
Import GPG keys to check packages validity
Then simply type yum install proftpd and it will automatically install the last version, I'd recommand you to yum update, this will update automaticaly mysql apache php to your latest version, make sure theses packages are not in the exclusion list of your yum.conf so.
Hope it helps.
	[utterramblings]
name=Jason's Utter Ramblings Repo
baseurl=http://www.jasonlitka.com/media/EL$releasever/$basearch/
enabled=1
gpgcheck=1
gpgkey=http://www.jasonlitka.com/media/RPM-GPG-KEY-jlitka
[dag]
name=Dag RPM Repository for Red Hat Enterprise Linux
baseurl=http://apt.sw.be/redhat/el$releasever/en/$basearch/dag
gpgcheck=1
enabled=1
	[B]rpm --import http://dag.wieers.com/packages/RPM-GPG-KEY.dag.txt[/B]
[B]rpm --import [/B][B]http://www.jasonlitka.com/media/RPM-GPG-KEY-jlitka[/B]
	Hope it helps.
