M MikeT New Member Jan 6, 2009 #1 Hello, I show two different memory reading, WHM shows 95% Parallel shows 24% Which one is correct and why do they show different ?
B Bryan Very Happy KH VPS User Jan 6, 2009 #2 If I'm not mistaken, VZ factors in your burst RAM. You obviously don't want to be counting on those numbers.
Dan Moderator Jan 7, 2009 #3 Hello Mike, For your most accurate readings you should check in SSH using the command 'top' or 'free'.
P ppc Moderator Jan 10, 2009 #4 Dan said: Hello Mike, For your most accurate readings you should check in SSH using the command 'top' or 'free'. Click to expand... I always heard Parallels PP was more accurate.
