P pereira New Member Jul 1, 2007 #1 The Burst RAM functions as swap of windows? How I can know if it is functioning?
M Mashahood VPS Ltx User Jul 2, 2007 #2 Burst RAM is the maximum amount of RAM you can receive when the physical resources are available, it is different then the swap memory
P pereira New Member Jul 2, 2007 #3 In a plan of 256 of RAM and 768 of burst ram I can consider that I have 1024 total?
M Mashahood VPS Ltx User Jul 2, 2007 #4 It will be 256 MB of ram which is granted for you, you will not get less then that, and 768 will be the Maximum limit if available on server (it should be available coz knownhost have 8 GB of ram on each of there server)
Dan Moderator Jul 2, 2007 #6 Burstable means that it is available for short durations of time when load spikes occur.
