INSTALLING Zend Optimizer
Discussion in 'DirectAdmin HOWTOs and Tutorials' started by VibrantStream.com, Aug 3, 2007.
  1. VibrantStream.com
    VibrantStream.com New Member
    To install Zend Optimizer:
    1. Login to your server via SSH
    2. Run: /scripts/installzendopt
    3. Follow the instructions on the screen to install Zend Optimizer
  2. BAlGaInTl
    BAlGaInTl New Member
    The following will install/update Zend for DA
     cd /usr/local/directadmin/customapache
    ./build clean
    ./build update
    ./build zend
  3. ppc
    ppc Moderator
    Thread edited. Please refer to BAIGAINTL's tutorial. VibrantStream.com tutorial was meant for Cpanel.
  4. BAlGaInTl
    Also... having found out the hard way...
    If you have Installatron on your VPS, it is incompatible with Zend 3.3.0. The Installatron links will not show up properly in your control panel with both installed. You will need to stick to version 3.2.8 which works fine.
    I believe that 3.2.8 is still the default version for DA and customapache.
    To revert, you can follow the directions above for installing Zend. This should revert you back to 3.2.8
    More information here:
    http://installatron.com/troubleshooting#missinglinks
    Afterwords, you will have to do an Installatron repair. To repair Installatron, you can do thw following:
    curl -O http://data1.liquenox.com/installatron/repair
    /usr/local/bin/php -n -q repair -f
  5. SaCron
    SaCron New Member
    If your having any problems with Zend, try this.
    Its a possible fix.
    It simply Cleans and Updates Zend to the newest version available.
    ./build clean
    ./build update
    ./build zend
  6. chrisd
    chrisd New Member
    FYI I did not need to manually install Zend Optimizer on my new KnownHost VPS account. It came with PHP 4.4.9 with Zend enabled.
    However, when I upgraded to PHP5 using DirectAdmin's custombuild tool, I did need to specifically enable Zend in the options.conf file. It was disabled by default. Instructions for using custombuild to upgrade to PHP5 are here:
    [http] forums.knownhost.com/showpost.php?p=13181
    [Because I'm a new user, the forum helpfully won't allow me to post clickable links. You will need to copy and paste the link above.]
Share This Page
